Naxos Posted August 26, 2004 Share Posted August 26, 2004 I have purchased 19" wheels 91/2 and 81/2 with 38mm offset for my GS400 and have also lowered the car with LSportline shocks and springs. I have been advised from the wheel guys to put 275/30/19 and 245/35/19 tires on the car. I need to know if 275/35/19 and 245/40/19 tires will fit on my car with no rubbing. I would prefer the taller profile. Can someone help me? Naxos I_have_purchased_staggered_19 Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 27, 2004 Share Posted August 27, 2004 moved to the wheel and tires forum Quote Link to comment Share on other sites More sharing options...
Neo Posted August 27, 2004 Share Posted August 27, 2004 I have purchased 19" wheels 91/2 and 81/2 with 38mm offset for my GS400 and have also lowered the car with LSportline shocks and springs. I have been advised from the wheel guys to put 275/30/19 and 245/35/19 tires on the car. I need to know if 275/35/19 and 245/40/19 tires will fit on my car with no rubbing. I would prefer the taller profile. Can someone help me?Naxos How low is the drop with the L-Sportline? The offsets of your wheels seem OK. Depending on the drop, you may have some problems with full turns on an incline (like entering a driveway) where the springs are compressed. The taller setup is like having 20s in terms of outside diameter. You will also be out of spec in terms of your speedometer and odometer since the outside diameter is larger than the stock size. Quote Link to comment Share on other sites More sharing options...
