m2pc Posted August 26, 2004 Share Posted August 26, 2004 Wanted to know if anyone has had a similiar experience. I just changed out my oil and tranny fluid. Oil was 10W-30 Mobil1 ( about 3/4 to 1 quart short till I could see better what the level was). Went away on vacation and 4 days later I went to start it up. My Goodness, I never heard it sound so bad....It was as if it could not turn over as well as shaking like no tommorrow for about 2-3 seconds which seemed like eternity, then it trurned over by itself and ran normally. This has never happened and since that rough start, has not happened since. All I can think of is that I drained and filled a quart short and the Mobil1 must have drained off all the metal parts. Any thoughts? Should I be concerned? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 26, 2004 Share Posted August 26, 2004 I doubt you drainded it too much or too low. A bone dry engine will start just with a little more harshness. I might say you had a bit of oil drip down into the cylinder chamber causing it to idle bad for a minute until burnt. Quote Link to comment Share on other sites More sharing options...
m2pc Posted August 26, 2004 Author Share Posted August 26, 2004 Thanks SK, so no worries? I'm about to start her up this morning Quote Link to comment Share on other sites More sharing options...
jragosta Posted August 26, 2004 Share Posted August 26, 2004 Wanted to know if anyone has had a similiar experience. I just changed out my oil and tranny fluid. Oil was 10W-30 Mobil1 ( about 3/4 to 1 quart short till I could see better what the level was). Went away on vacation and 4 days later I went to start it up. My Goodness, I never heard it sound so bad....It was as if it could not turn over as well as shaking like no tommorrow for about 2-3 seconds which seemed like eternity, then it trurned over by itself and ran normally. This has never happened and since that rough start, has not happened since. All I can think of is that I drained and filled a quart short and the Mobil1 must have drained off all the metal parts. Any thoughts? Should I be concerned? Can you be a bit more specific? You said that it sounded like it wouldn't turn over. Did the engine crank normally or are you talking about slow cranking? If you can describe the symptoms more fully, it will help with the diagnosis. But SK's explanation seems reasonable. I just can't figure out how you had oil drip down into the cylinder from a simple oil change. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 26, 2004 Share Posted August 26, 2004 new synthetic oil cleans off old debris easily and can cause small short leaks where normal oil has been used and the gaskets have swollen Quote Link to comment Share on other sites More sharing options...
m2pc Posted August 26, 2004 Author Share Posted August 26, 2004 I really don't know how to describe it. It felt like a strong crank, but not synchronizied. What I mean is it felt like the engine was turning over and the best way I can think of is that it felt like it wanted to start, but then wouldn't then wnated to start again and then vroom, started. I think there was a bit of shakin as well. But started again this morning and very smooth as I would hope. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 27, 2004 Share Posted August 27, 2004 try turnig the key a few times to prime the pump and pressure of the system to see if it stops it may be a bad pump or filter if it does stop Quote Link to comment Share on other sites More sharing options...
m2pc Posted August 27, 2004 Author Share Posted August 27, 2004 Starts like a champ now. Didn't do anything different. Car must had thought it was still on vacation :D Quote Link to comment Share on other sites More sharing options...
