mago Posted August 24, 2004 Share Posted August 24, 2004 Is anyone having an occasional problem with trying to open the power deck door with the key fob and or the button on the dash? At times we cannot open the rear door using both of the above. I took it into the Lexus dealer and they greased the latch. Tom Wolf Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 24, 2004 Share Posted August 24, 2004 been asked before you need to make sure it is fully closed properly first Quote Link to comment Share on other sites More sharing options...
Unlisted Posted August 24, 2004 Share Posted August 24, 2004 the trick is to make sure all 4 doors are unlocked. You must hit unlock button on key twice in 3 seconds then hit trunk release and hold. that should do the trick. Also in the glove box on the left outter edge there is a cutoff switch. If it is in the out mode the rear door will not work electronically for safety{ opening inside the garage} reasons Quote Link to comment Share on other sites More sharing options...
kh046 Posted August 25, 2004 Share Posted August 25, 2004 You might want to seach this site for that particular problem. I had that problem with my RX330 as well. My only problem with taking my RX to the dealership is that will work perfectly fine when I'm there. Somehow, my Rx tended not to work whenever I was at Costco (????). They way that I made it work again was to manually opening the hatch and manually closing it. Somehow this resets the hatch's operation. To make a long story short, I saw a member post an ECU part number on this site. I copied that information down and took it to my dealership. They took my paper and ordered the part for me. Although it took them almost 2 months to get the part, they were able to replace it for me. After replacing the ECU, I haven't had that happen to me since April. My advice, check this site for the ECU part, copy it down, and take it to your dealership. They have the part. If you don't ask, they won't give. That is the only thing that I dislike about dealers. Quote Link to comment Share on other sites More sharing options...
adman@nefco Posted August 25, 2004 Share Posted August 25, 2004 Ther is a TSB # ELOO2R-04 dated April /04 it states Body- Power Back Door inoperative - update Ask your dealer to review this TSB with you I hope it helps. TSB's can be found at www.alldata.com Quote Link to comment Share on other sites More sharing options...
