aWifeN3Boys Posted May 15, 2003 Posted May 15, 2003 Have never had this problem before: when ac is running, cold air only comes out the two center air vents. The other four vents are blowing "warm-ambient" air. My guess is something to do with the air ducts behind the dashboard--->I don't want to take the dashboard out if not neccessary. Any advice.....???
NYPD Posted May 15, 2003 Posted May 15, 2003 Try putting the heat on and also changing the air flow via the control panel. Maybe something is stuck and this may loosen it up. It's worth a try.
meZoom! Posted May 15, 2003 Posted May 15, 2003 "cold air only coming out of center vents" was one of my first complaints/symptoms before my a/c stopped blowing cold air altogether. i've told the story quite a few times somewhere else, but basically, i think the expansion valve was stuck in the end.
Steve Posted May 15, 2003 Posted May 15, 2003 the motor may be faulty. with the temp on at 26 and just sit and listen you will hear a small motor noise behind the dash every so often.. this controls the temprature in the car.. this open and closes the valves... i reckon the motor is stuck hope that makes sense
SKperformance Posted May 15, 2003 Posted May 15, 2003 with the key off press the auto and recirc button together and then turn the ley forward it will go into diagnostic mode after it checks all the lights it will show codes on the display if any post what they are and check the manual to see what it says
Steve Posted May 15, 2003 Posted May 15, 2003 never knew that pal!.. interesting. how do you get it back into normal mode?? just turn the key off?
aWifeN3Boys Posted June 11, 2003 Author Posted June 11, 2003 it took me awhile but I finally got a chance to check out the ac problem again.... 1. the motor for the vents are working ok...I can see(under driverside dashboard)/hear the motor moving when changing vent "modes". 2. I check for codes holding down auto and recirc.... a. the only numbers I saw were 00-flashing on the screen steadily b. while in diagnostic mode I pressed the recirc again and it ran from codes "20-29" running all the test that it needed to properly...as far as I can tell. 3. I checked the reservoir "sight glass" while ac was running and I can see the "stream" of freon moving by without it clearing up. Isn't the stream suppose to clear up after a while or am I wrong? My next step: Have a shop put dye in the system to check for leaks. Any more advice? :D
SKperformance Posted June 11, 2003 Posted June 11, 2003 following the kiss rule (keep it simple stupid) i am refering to me but did you check the position of the manual flap under each side vent the round thing that rotates left or right just thought 00 is normal doesn't seem to be a code for 20 or 29 oh sorry iread some more and you put it into actuator check mode where it checks each cuircit
