Hello all, my trunk light on my 99 gs 400 only comes on when I us the key to physically open it. When I use the remote on the key or from inside the car it does not work. I appreciate any suggestions.
grease the tunk latch with wd40 a good bit it may be hard and the solenoid is not pulling it far enough to activate the light on the latch while you turning the key does
I took apart the trunk latch assembly cover to discover the metal connector that activates the light when the trunk is opened had some sort of dirt film on it. I cleaned the metal off and lubed the latch assembly, had no problem since the lights in the trunk comes on whe n the trunk is opened with the remote. Thanks for the help.
