blueviol Posted June 13, 2004 Share Posted June 13, 2004 My 95 SC400's rear brake rotors are not being worn at the full width. Only inner half of the circular rotor is being worn by the pad, leaving the rotor look very ugly and I feel weakness in braking as well. Is this something to do with the caliper not working properly? I was advised to clean the pistons. I would appreciate any feedback. Thanks. Quote Link to comment Share on other sites More sharing options...
AWJ Posted June 13, 2004 Share Posted June 13, 2004 Wheel could be over torqued. Pads could be broken or uneven. Caliper could need a rebuild. You might have a fluid leak or not enough to begin with. I'd recommend a good brake job. Or pull the piston and rebuild it. Your call. Your brakes. I would do something soon though if braking distance is being sacrificed. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 13, 2004 Share Posted June 13, 2004 clean the pistons Quote Link to comment Share on other sites More sharing options...
blueviol Posted June 14, 2004 Author Share Posted June 14, 2004 I see. I also think the piston needs to be cleaned. Thanks. Quote Link to comment Share on other sites More sharing options...
Lexussc400Sugarland Posted June 15, 2004 Share Posted June 15, 2004 i think you should replace the rear rotors put some wagner thermal quiets first than rebuild the calipers i had the same problem side note its not made like a supra dont brake like one thats my problem too brakes tend to wear with ownership of a good radar detector:} Quote Link to comment Share on other sites More sharing options...
blueviol Posted June 15, 2004 Author Share Posted June 15, 2004 What is the Wagner Thermal quiet? ^^ I guess mine started causing problem since I got my Valentine One... kkk --------------------- brakes tend to wear with ownership of a good radar detector:} Quote Link to comment Share on other sites More sharing options...
