landonm75 Posted September 12, 2022 Share Posted September 12, 2022 Hello everyone. I have looked and read high and low for an answer to my problem and tried many fixes to no avail. My 2001 RX300 recently displayed a VSC, check engine and ABS light. After traveling for a few minutes the brakes build up pressure and lock on to the rotors. I have replaced fuses, relays, master cylinder, cleaned and inspected pressure sensors on each wheel, and replaced brake light switch. Nothing has worked. Are there any other things I can replace or fix? I replaced the knock sensors just before this started but they seem to be unrelated. Please help. Landon Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 12, 2022 Share Posted September 12, 2022 Could this be the issue? Lexus RX300 ABS kicks in/antilock brake activation when not needed (carspecmn.com) Quote Link to comment Share on other sites More sharing options...
landonm75 Posted September 12, 2022 Author Share Posted September 12, 2022 Thank you. I will look at that this evening. Seems like a really big job so I hope that is not it but the description of the problem definitely seems similar. Quote Link to comment Share on other sites More sharing options...
