All Activity
This stream auto-updates
  1. Yesterday
  2. We have a 2005 ES330 with 142K on the clock. I replaced the strut assemblies with aftermarket parts and we no longer have a smooth, silent ride. I am willing to bite the bullet and do what might be needed to restore it to Lexus like ride and handling. It's smooth at highway speeds, but noisy and not smooth at slow speeds, especially on uneven surfaces. Any suggestions for shocks/struts that will improve the situation would be appreciated.
  3. Thanks to everyone on the suggestions for trunk lid issues; saved me many dollars hours of frustration.
  4. Another newbie. Joins May 24th, posts for help. Never comes back, never updates or says thanks.
  5. 1997 LS400 steering wheel not moving back and forward but moves up and down? Any solution?
  6. Yes, thank you. Bought it for 1k last week because the guy didn't want to diagnose the problem. 187k miles interior great condition outside cosmetic ok/good condition. Fix cost me 20 dollars for a harbor freight tool set and a willingness to learn. Overall I figure it was a good deal. Now I have a beautiful piece of engineering mastery(1mz) and a ride that does fake wood grain tastefully haha. My friend has an RX also and we might start one of those riding clubs named soccer mom squad (neither of us moms, or women) out of irony
  7. Last week
  8. Congrats on discovering the culprit! 馃憤
  9. Sorry all. I was wrong. Turns out the bank2 cat was completely destroyed lodging the honeycomb down into the down pipe. I realized this by loosening the bolts from cat to header just a couple turns and got power back with no misfires anymore.
  10. The radio fixed itself! I went back to the Lexus dealer to return the map data card. It wasn't returnable, but the parts guy connected me with the tech advisor, the person that helps you with all the settings on the car. He told me he was not a technician, but would try to help verify the problem. We went to the car and plugged in the SD card. When I turned the car on there was no boot sequence, but a message appeared "Checking for map info," which I hadn't seen before. It then went blank. After a couple of minutes, we turned the car off. He said to get it checked out by a tech for $237 or go to a nearby non dealer Toyota/Lexus shop. I then drove 10 minutes to get lunch. I then drove another 15 minutes to do some shopping. When I started the car next, the system booted and the new map data was there. Furthermore, all of my radio settings and saved addresses were still there, even though I had disconnected the battery for half an hour when I first discovered the problem. The lessoned learned was don't freak out if it first doesn't boot right away after a map update, just be really patient. This will be my last map update. __________________ Tom Scott San Diego 2016 ES 300H Eminent Pearl White. All of the bells and whistles except ML sound system
  11. I have a 2001 rx300 that will not go into any gear. Gear shifter just moves freely but no connection. I think it may be the shifter came unattached from the transmission linkage. I've heard the bushings grow fragile. If that is the case how do I get to the bushing to replace it? Thank you.
  12. 2002 LS430 Pearl white camel / tan color seats Located in Columbus, Ga Had a mechanic shop test the engine.. 1 fender bender needed new bumper and left head light, left front qrt panel 2,500 asking
  13. What year and model is car. Interior and exterior color. where is the car located. any other major repairs or accidents. How do you know it just needs valaves and not a total rebuilt. How much are you asking. This has to be the goofiest for sale post I ever saw.
  14. Car need valve job and smokes Car in great shape 160K miles on it BEST OFFER!
  15. INTRO Hi all, I have an ES300, and ever since I got it, the engine starts bucking when it has been running for a while and/or I floor it. THE PROBLEM What specifically happens is when I accelerate, before it shifts into second or third, (it only seems to have problems with these gears) the RPMs spike to 5,500 to 6,000, the car slows way down, the engine seems to buck (it feels like I hit a speed bump going about 30mph). POSSIBLE COINCIDENCE The bank 2 (front) catalytic converter code starts to show whenever this happens. I don't know if this is a coincidence, but it's frustrating. I see the problem isn't the catalytic converter because I bought a new one and put it on, and it didn't fix the problem, so I cleaned the old cat and put it back on. after that, the code for the catalytic converter didn't come back on for a while. WHAT THE MECHANIC SAID The mechanic said that it was most likely either the transmission or the catalytic converter. I mentioned knock sensors but he said that he has never had a knock sensor not throw a code when it died. WHAT I DID My friend had the same problem in his ES300 that was from the previous generation, and he said that they replaced the knock sensors and fixed the problem, even though the dealership told them it was the transmission. So I replaced the knock sensors and all the gaskets we took off in the process. THE FIX It seemed to work, I took it on the freeway and kept flooring it to get the engine hot, and it didn't buck when I had previously tested it, and it failed, with the new catalytic converter. So to make sure, I took a drive that was pretty much the same drive I had taken the summer before when I realized this was a big problem. This time, with the engine only resting about an hour or two before I drove back, the car had no issues. all seemed well in the world. THE PROBLEM RETURNS the other day I wanted to race my friend, and for the first time since I had tested the car on the freeway, I floored it. but this time it bucked again when it was trying to shift into second or third (I can't remember which one) and a few days later the same cat code I had before appeared. POSSIBLE FACTORS since I got the car, it has jerked whenever I put it in reverse I think there are 5 motor mounts in the car, and 3 or 4 of them are bad the power steering pump was leaking very slowly for a while, which made me burn through belts very fast (fixed now) I appreciate any tips that you guys have for diagnosing this, I want to get this fixed but i don't want to pay a mechanic an insane amount of money to diagnose it and be wrong. Thank you all for your help.
  16. Yes, looking like it was the injectors after all. I cleaned two of them four and six and rescanned and only cylinder two still had the misfire code active on it which I'm about to take off that one and clean it as well. I'm not sure why I didn't do it in the first place. I figured it was the only one working from my initial plug test so I just Left to be
  17. My 2008 SC 430 has a bad windshield washer switch. The local Toyota dealer quoted me $600.00 to replace it which sounds excessive to me. Anyone ever done this or had it done? Thanks
  18. P another thing I've been noticing is as I've been driving it more. The drivability has actually increased dramatically from when I first purchased the vehicle so that makes me leave that. Maybe I'm lodging something loose within the injectors but I will keep you updated
  19. Thank you for the recommendations. I loosened one of the exhaust connectors to see if letting more exhaust gases out would change anything but it did not end. As for the clodcat, I loosened the exhaust pre-cat. I'm sort of leaning towards possibly a dirty injector because as I was showing my friend what was going on, I went and unplugged bank 2 injectors and only one of the injectors created a noticeable change with the engine running. While the other two injectors had little or no change as I unplugged them, so I'm assuming they're either dead or clogged or there's an issue in the circus somewhere. I don't have a multimeter so it's going to be difficult to test but I do have a ODB scanner that offers active testing and I'll probably just pull the injectors and activate the function and see if they start pulsing
  20. Have you also considered any of these possibilities?
  21. Your choice is pure Lexus, Anyone can buy aftermarket, But to have the real thing is Superb !!!
  1. Load more activity
