All Activity
This stream auto-updates
  1. Past hour
  2. Today
  3. Yesterday
  4. Thanks, am going to replace, it is worn. Have found am OEM with 8,000 miles with guarantee
  5. Last week
  6. Will an armrest cover for a 2003 lexus rx300 fit a 2000 rx300?
  7. nothing that i no of , i have adjusted my front to rear the best it can be , the rear speakers are to small , even with the fader set 3 clicks to the rear , just a poor system ,
  8. I have the same problem. When I go to the screen to adjust the front rear fade, it is greyed out and cannot be adjusted. Do I need to turn something else off to gain this function?
  9. Has anyone tried this without emptying all the coolant out, just the radiator? I don't have the best ramps to get underneath the engine to drain the spigots by the O2 sensors.
  10. I put a post up on the RX350 page, same thing with the key. 500 miles and while my wife is out of town a rock hits the windshield. The glass company ordered a new one from Lexus today only to be told they are on backorder with no ETA. This is my third Lexus, VERY disappointed in the experience with this new car. I don't look for a change as long as we keep buying.
  11. I have been all over this forum since picking up a 99 RX300 the other day. Car has 139k on it. Awesome info in here! Mine has the dreaded 2-3 shift issue, the kicker is, guy I got it from just had the transmission replaced with a 50k mile JDM because of said issue. Got the car back and it was still doing the same thing with the new trans in it. Now some research I have done on the JDM transmissions is that they say you have to use the solenoids from the stock trans as they do not come with them, maybe I read wrong. That being said could it be the solenoids themselves. Also I see that there is a “shift improvement kit” anyone have experience with them and do you think I am on to something with the solenoids? Thank you
  12. The dealer had no idea how long it would take, from reading 6 months is not out of the question. How long has it taken to get your second key? Also, My wife got hit by a rock on the interstate today (500 miles on car) and cracked the windshield pretty bad. State Farm sent me to a local shop who ordered me a new windshield from Lexus (2024 RX350 Luxury) and was told the windshields were on backorder with no ETA on arrival. Guess we will ride around with a cracked windshield while we wait on a key....DOH!
  13. Lacking a switch, perhaps there is a fuse you could remove. That's assuming it has a fuse that's only for the charging pad..
  14. Good afternoon all, Within the past 4 months using the phone on my wife's 13 RX350 has all changed due to static and connectivity issues. We have never done a software update. Has anyone else had a problem like this? If so, what was the remedy please?
  15. I saw in the news this morning that Toyota is apologizing for incorrect testing of some Toyota and Lexus vehicles. The article said that some specs were not accurate including safety, torque and engine torque for some cars. The article I read was not clear on whether this included the US models. This comes on the heels of a pending recall for engine manufacturing debris that was left in some motors. They are reviewing a plan to repair these now. Along side this report, several other Japanese car companies stated similar failings. More importantly, I would like to say I have a lot of trust in Toyota. I have owned their cars for years with stellar results. I am sure they will get their hands around each of these issues. I just bought a new Lexus ES350 Saturday! Happy to be here.
  16. Check the race for damage and be sure you are using the correct tightening technique for the bearing load.
  17. Is there more than 1 motor that controls the movement of the steering wheel? when I move the switch back and forth there is no movement at all and I can hear a slight click in a ?relay? motor? so I assume the switch is working, and it works fine for up and down adjustment. I also disconnected the battery for aa few minutes to srr if that would reset anything but it didn't help. Thanks for your input Dave.
  18. I already turned the gear around and regreased it...works fine up and down but still not telescoping....the motor sounds fine and gearbox is quiet....I may just buy and replace the gear.
  19. Have you tried KYB? I've used them in the past (Mazda MX6) and was happy with them. 2005 LEXUS ES330 3.3L V6 Shock / Strut | RockAuto
  20. We have a 2005 ES330 with 142K on the clock. I replaced the strut assemblies with aftermarket parts and we no longer have a smooth, silent ride. I am willing to bite the bullet and do what might be needed to restore it to Lexus like ride and handling. It's smooth at highway speeds, but noisy and not smooth at slow speeds, especially on uneven surfaces. Any suggestions for shocks/struts that will improve the situation would be appreciated.
  21. Thanks to everyone on the suggestions for trunk lid issues; saved me many dollars hours of frustration.
  22. Another newbie. Joins May 24th, posts for help. Never comes back, never updates or says thanks.
  23. 1997 LS400 steering wheel not moving back and forward but moves up and down? Any solution?
  1. Load more activity
