PilotguyPA28 Posted June 29, 2010 Share Posted June 29, 2010 Is the battery just an unscrew and replace at Radio Shack? I see a small screw on one side of the key. Does that let you pop open the two sides to replace the battery? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
intakerGS Posted June 29, 2010 Share Posted June 29, 2010 Yes. Use an appropriately sized screw driver to avoid stripping the head. Pry open the two parts, careful not to loose the rubber O ring inside and take note of the position of the battery. Replace with CR1216 or 1616. Quote Link to comment Share on other sites More sharing options...
PilotguyPA28 Posted June 29, 2010 Author Share Posted June 29, 2010 Thanks IntakerGS! Quote Link to comment Share on other sites More sharing options...
landar Posted June 30, 2010 Share Posted June 30, 2010 Is the battery just an unscrew and replace at Radio Shack? I see a small screw on one side of the key. Does that let you pop open the two sides to replace the battery? Thanks in advance. I just replaced a battery. Very easy to do. There is one screw to get the outer case apart, then an inner battery compartment held with 2 more screws. Remove the inner compartment and replace the old battery (+ facing up). Quote Link to comment Share on other sites More sharing options...
FatCat23 Posted August 18, 2010 Share Posted August 18, 2010 I changed my battery as described, but not when I press the unlock button it only unlocks the passenger doors and the rear drivers side door. The only way to unlock the drivers door is to use the actual key. Any ideas on how to remedy this? Reprogram something? Thanks! Quote Link to comment Share on other sites More sharing options...
landar Posted August 18, 2010 Share Posted August 18, 2010 I changed my battery as described, but not when I press the unlock button it only unlocks the passenger doors and the rear drivers side door. The only way to unlock the drivers door is to use the actual key. Any ideas on how to remedy this? Reprogram something? Thanks! I would not think a battery replacement would affect the sequence of unlocking. Do you have a spare key fob remote that you can try? If that remote unlocks all doors then maybe something is wrong with the other fob (although I doubt it). And your car is an '03? Quote Link to comment Share on other sites More sharing options...
