95 Speakers
the speaker is a 6x9 size
you need to remove the back seats
upper ( 2 bolts at the bottom then pushes up)
and
lower( it pops up in 3 places)
then take the 3rd brake light out it need to pull forward
( toward the front of the car)
remove the rear side upper panels to get the parcel shelf out
then just a few screw to release the speaker and connections
if replacing one replace them both
cheapest is to get an aftermarket pair
it is a waste of time to replace just one
and splice the wiring to new connectors
goddluck
average time is about
2.5 hours to remove and replace
not much tools though a basic socket set
the amp is under thepassenger front seat
if you are going that route
rewire all the speakers to the trunk and put the amp in there
also speaker are too personal of a choice
even in the same car
listen to some on the audio borads at electronics stores to see what you like then decide i can tell you what i like and have but you probably wouldn't like it or want to spend it
well i maybe gettin a 2000watt 2ch Legacy amp with 2 12" 1000watt Eclipse Allum Subs. thats just for show. i just checked under my passenger seat. is the amp the little black box that says Toyota on it?
yah that is the amp
just a thought but legacy products are junk
just as there lower company pyramid
all the same components just diferent case
and as for the 2000 watts
it is more like 200 watts it is just full of distortion
the subs are not bad though
imho
later
