wasabi01 Posted September 27, 2007 Share Posted September 27, 2007 anyone know how to take out the front turn signal light bulbs? Quote Link to comment Share on other sites More sharing options...
izzy300 Posted September 27, 2007 Share Posted September 27, 2007 anyone know how to take out the front turn signal light bulbs? Pop the hood and look at how to get to the back of the headlight housing under the radiator support (Basically the huge horizontal piece of metal behind the grill) Look on the outside where the headlights are mounted. There should be wires running into harnesses going into the rear of the headlights housing. You want the OUTER housing on both headlights. Then it's left loosy on the plastic bulb housing that the wires run into, swap the bulb and twist her (righty tighty) back in fresh and ready to go. Haven't done it but it looks simple enough on paper. good luck Quote Link to comment Share on other sites More sharing options...
IS3_FTW Posted October 2, 2007 Share Posted October 2, 2007 anyone know how to take out the front turn signal light bulbs? Just to let you know, its not easy. You have to take off your front bumper, then you headlights to change your signal. Also, to do the license plate light is even harder to figure out. Hope this helps if you stilll in need of it. Quote Link to comment Share on other sites More sharing options...
IS3_FTW Posted October 3, 2007 Share Posted October 3, 2007 Here is a DIY that will help you through your task of changing out your signal bulb. http://my.is/forums/showthread.php?t=22629...eferrerid=64148 Quote Link to comment Share on other sites More sharing options...
wasabi01 Posted October 5, 2007 Author Share Posted October 5, 2007 Here is a DIY that will help you through your task of changing out your signal bulb.http://my.is/forums/showthread.php?t=22629...eferrerid=64148 man it look like it takes alot of time just to change the corner lights. i'm going to try it and see what happen. thanks guys. anyone from las vegas? Quote Link to comment Share on other sites More sharing options...
bulldog5150 Posted October 16, 2007 Share Posted October 16, 2007 DUDE THIS IS NOT THAT DIFFICULT. DISCONNECT THE BATTERY, TAKE OUT THE BOLTS THAT HOLD THE HEADLIGHT HOUSING IN, TAKE OFF THE POP OFFS ON THE GRILL AND FINESS OUT AND UP, POP OUT THE SNAPS THAT HOLD THE WHEEL WELLS IN PLACE. USE A 1/4 DRIVE RATCHET AND AN EXTENSION WITH A TEN MILLIMETER MAGNETIC SOCKET. TAKE OUT THAT BOLD, THEN ITS A LITTLE BIT OF FINESS. SERIOUSLY IF YOU WORKED ON CARS FOR A LIVING YOU WOULD NEVER MAKE ANY MONEY. THATS REDICULOUS BRING ME YOUR CAR AND ILL CHARGE YOU THE THREE HOUR RATE THE DEALER WOULD CHARGE AT $95 PER HOUR, AND ILL DELIVER YOUR CAR TO YOU IN HALF AN HOUR..... Quote Link to comment Share on other sites More sharing options...
bartkat Posted October 16, 2007 Share Posted October 16, 2007 DUDE THIS IS NOT THAT DIFFICULT. DISCONNECT THE BATTERY, TAKE OUT THE BOLTS THAT HOLD THE HEADLIGHT HOUSING IN, TAKE OFF THE POP OFFS ON THE GRILL AND FINESS OUT AND UP, POP OUT THE SNAPS THAT HOLD THE WHEEL WELLS IN PLACE. USE A 1/4 DRIVE RATCHET AND AN EXTENSION WITH A TEN MILLIMETER MAGNETIC SOCKET. TAKE OUT THAT BOLD, THEN ITS A LITTLE BIT OF FINESS. SERIOUSLY IF YOU WORKED ON CARS FOR A LIVING YOU WOULD NEVER MAKE ANY MONEY. THATS REDICULOUS BRING ME YOUR CAR AND ILL CHARGE YOU THE THREE HOUR RATE THE DEALER WOULD CHARGE AT $95 PER HOUR, AND ILL DELIVER YOUR CAR TO YOU IN HALF AN HOUR..... If you want to answer the question, fine, but please don't badmouth the other poster. And please stop typingin all caps. Quote Link to comment Share on other sites More sharing options...
