I had bought a lexus 330, and I did not know how to set up a garage becuase I lost my guide book. Can someone help me on this. Thanks.
Do you mean to set up a garage in your home? If your intentions are to do maintenance on your car then you'll need some sort of mechanical/hydraulic lift as the first thing.......but you'll also need an area that has the proper ceiling height to raise the car fully. Next, you'll need a pretty decent set of mechanics tools. Last but not least is your ability & knowledge to do these maintenance or repairs yourself.
This will give you an idea as to what's involved: Auto Lift
usually you:
hold down the button in your Lexus for 30+ seconds.. it will start to blink differently.
then, while still holding the button in your car, move your garage opener to withing 1-2 inches of the Lexus button and depress the garage door opener and hold for 2+ seconds.
Your lexus will now flash differently (again)
Let go of lexus button and then you should be able to use it as the opener...
If you have "rolling code" technology on your garage opener...........there is a different procedure. I'll have to look that one up!!
Follow the link to the Homelink programming website. It will walk you right through it. If you have a rolling-code opener, pay special attention to the instructions.
Homelink Programming
