evaporator drain 2009 rx350
After run out using the ac i noticed that there was no water on the ground from the ac drain hose.... so under i went and hooked up an extension hose ... put my mouth on it and blow through  it and no blockage.... should i worry about this, just had the RX a week... pushing down on carpets they feel dry...
Hello Glenn, When using the AC it doesn't always drip after use, The drain is to exhaust extra condensation only. The excess water is evaporating before draining. Enjoy !!!
Thanks thats a relief
  • Like 1
