Lexygirlpa1 Posted May 6, 2004 Posted May 6, 2004 Hello everyone. I am new to this post and would appreciate any advice you may have regarding my 1998 ES300. The problem started recently and the first time it started was when it was raining. My car was parked and I used my remote to unlock my door (the alarm chirpped). When I tried to start the car, it wouldn't start. All of the dash board lights came on and when I tried to start the car again, they all went out. I got out of the car, closed the door and pressed the "unlock" button again. The alarm chirpped, but it was very slight this time. I opened the hood and pressed on the battery cables to make sure they were on tight (which they were) and I went over the the alarm and jiggled the wires a little. I hit the "unlock" button again on the remote and the alarm sounded - louder this time. I got back in the car and tried to start the car and it started. Initially, it seemed that everytime it rained, I had this problem. However, a few days ago, on a bright and sunny day, the same thing happened and I now cannot attribute it to the rain. Although it rained the night before. When I don't use the remote to open the door, the car starts with no problem. I changed the battery in the remote and my car's battery is only 19 months old. The alarm has a "kill switch" mechanism and that's what it seems like is happening when I hit the remote. Has anyone else experienced anything like this or know what could be causing the car not to start. Thanks for any replies.
SKperformance Posted May 6, 2004 Posted May 6, 2004 umm you jiggled the alarms wires? are you sure you have a stock alarm or an aftermarket one installed in the car ?
exdotcomer Posted May 7, 2004 Posted May 7, 2004 I would definitely check that out at a local audio installation shop ( a good one) you don't want to get stranded somewhere. could be a lose wire, contact or something, keep us updated.
Jimmy G Posted May 23, 2004 Posted May 23, 2004 Hello everyone. I am new to this post and would appreciate any advice you may have regarding my 1998 ES300. The problem started recently and the first time it started was when it was raining. My car was parked and I used my remote to unlock my door (the alarm chirpped). When I tried to start the car, it wouldn't start. All of the dash board lights came on and when I tried to start the car again, they all went out. I got out of the car, closed the door and pressed the "unlock" button again. The alarm chirpped, but it was very slight this time. I opened the hood and pressed on the battery cables to make sure they were on tight (which they were) and I went over the the alarm and jiggled the wires a little. I hit the "unlock" button again on the remote and the alarm sounded - louder this time. I got back in the car and tried to start the car and it started. Initially, it seemed that everytime it rained, I had this problem. However, a few days ago, on a bright and sunny day, the same thing happened and I now cannot attribute it to the rain. Although it rained the night before. When I don't use the remote to open the door, the car starts with no problem. I changed the battery in the remote and my car's battery is only 19 months old. The alarm has a "kill switch" mechanism and that's what it seems like is happening when I hit the remote. Has anyone else experienced anything like this or know what could be causing the car not to start. Thanks for any replies. I had a similar problem. My alarm went off. I put the key in the ignition to turn it off. Then the car wouldn't start. I had to use the remote to reset (lock/unlock the door) before the car would start again. Jim
