Looking for the location of the wiper relays on my 1999 LS 400. Anyone?
Wipers only work on high speed. No low or intermittent speeds. Does not park properly.
  • 3 months later...
There is no relay for the wiper. You have to inspect it at the wiper motor connector. If both high and low speeds are working at the motor, then you have to troubleshoot the switch. It maybe as simple as dirty connector.
  • 2 years later...
I have a 2000 LS 400 in pristine condition but the wipers only work on high speed and the wipers stop any where I changed the switch and the motor but that did not solved the problem. I would appreciate any help
  • Like 1
The Body ECU is bad.
