Brake Fluid Replacement at 40K miles
Per the 2014 RX350 maintenance manual at the following link, brake fluid is to be replaced every 30,000 miles or 36 months whichever comes first:
https://drivers.lexus.com/t3Portal/document/omms-s/L-MMS-14RX350/pdf/MY14_Lexus RX 350_WSG_lr.pdf
That seems odd since the braking system on our 2014 Toyota Sienna is virtually identical as is the braking system on the Toyota Highlander.  Changing the brake fluid on the Sienna is not in its maintenance schedule and is considered "lifetime".
  • 5 months later...
Porsche recommends changing brake fluid every two years.  It absorbs moisture from the air, so mileage isn't really a factor.  You can purchase brake fluid testers from Amazon and check it yourself.  If you are going to keep the car for an extended period I would change it every two years.
