BardPeterson Posted April 17, 2018 Posted April 17, 2018 Just bought a 04 rx 330 with 60,000 miles for $11,750 usd, grampa driven,cherry condition ,built in Japan ,no recalls,anything in particular I should be doing for it?
Benjiex Posted April 17, 2018 Posted April 17, 2018 You still need a mechanic to check it up. Sometimes there are hidden problems that you will not know unless you have it check. ;)
Steve Posted April 17, 2018 Posted April 17, 2018 Visit your local dealer, have the VIN checked for any recalls and see if they have all been done.
BardPeterson Posted April 17, 2018 Author Posted April 17, 2018 Thanks guys ,checked the vin at Lexus site said no recalls ,did have repurchase inspection done,said tiny leak in power steering pressure hose , loose bolt on radiator bracket ,rear bumper not perfectly aligned grampa bumped into something ,70 % remaining on original bakes ,that's all they listed.
virtualking Posted July 4, 2018 Posted July 4, 2018 You should contact a mechanic to check it up and see if any problem is there and checkout all the things properly
