Just bought a 04 rx 330 with 60,000 miles for $11,750 usd, grampa driven,cherry condition ,built in Japan ,no recalls,anything in particular I should be doing for it?
You still need a mechanic to check it up. Sometimes there are hidden problems that you will not know unless you have it check. ;)
Visit your local dealer, have the VIN checked for any recalls and see if they have all been done.
Thanks guys ,checked the vin at Lexus site said no recalls ,did have repurchase inspection done,said tiny leak in power steering pressure hose , loose bolt on radiator bracket ,rear bumper not perfectly aligned grampa bumped into something ,70 % remaining on original bakes ,that's all they listed.
  • 2 months later...
You should contact a mechanic to check it up and see if any problem is there and checkout all the things properly
