92ls400lexus Posted August 16, 2016 Share Posted August 16, 2016 I have a 92 ls400 with about 290k on the engine. Just recently while trying to fix some fans apparently the computer fried and not its not running the dealer said I can do a complete engine swap or look for the harnessing and replace it all.. Has anyone had to do this? What would be the best way to go about getting it up and going again Quote Link to comment Share on other sites More sharing options...
TrevC Posted August 16, 2016 Share Posted August 16, 2016 Hi Ben...welcome to the Club! A bit confused by the 'computer fried' since fitting fans...what actually occurred? Cheers, Trevor Quote Link to comment Share on other sites More sharing options...
92ls400lexus Posted August 17, 2016 Author Share Posted August 17, 2016 Hi and thank you. I was fixing a hose and noticed the front fan was not working so I removed the fan. Since I did that the car would try to start but no luck in actually getting it going. I took it to a mechanic and he said that being that I had the car on when messing with the fans it fried the computer/wiring harness? Quote Link to comment Share on other sites More sharing options...
TrevC Posted August 18, 2016 Share Posted August 18, 2016 Very unlikely that would occur as the fans would run through a fuse which will just blow if you short circuit the system. More than likely, you may have dislodged a sensor. I would look in the area you were working in and see if there is any wiring or connectors going to any sensors on the engine, in particular the Crankshaft Sensor. Quote Link to comment Share on other sites More sharing options...
92ls400lexus Posted August 18, 2016 Author Share Posted August 18, 2016 I actually replaced the crankshaft sensor after the car stopped starting and didn't seem to effect it.the car won't run but it turns on still, windows radio etc still function .. should I take it to another mechanic? It's the ecu that he was saying was out. And being on a tight budget when I looked online I found some cheap ones are they easy to install? Quote Link to comment Share on other sites More sharing options...
92ls400lexus Posted August 18, 2016 Author Share Posted August 18, 2016 I just really really don't want to get rid of this car if i can help it best car I've owned so far , still has lots of potential Quote Link to comment Share on other sites More sharing options...
92ls400lexus Posted August 18, 2016 Author Share Posted August 18, 2016 I remember looking at the vehicle. The ECU is damaged from being shorted to power on it's ground. The ECU needs to be replaced, or disassembled and repaired by a professional technology company .... This is what the mechanic sent me so maybe im wording things wrong but anyhow ...do you have any idea what a fix like this would range around and whats easiest way to go about getting it fixed? Quote Link to comment Share on other sites More sharing options...
TrevC Posted August 23, 2016 Share Posted August 23, 2016 If it's a case of another ECU it will have to be coded into the car and probably the best thing is to get your own one rebuilt and therefore no need to recode Quote Link to comment Share on other sites More sharing options...
