Hello,
Since yesterday, impossible to close the rear passenger door.
Normally we do not slam the door on the approach and electrically it closes. There can not close the door either mechanically or electrically.
To complete the journey I had to strap both armrests left and right rear doors if not impossible to continue the road.
I tried the inner closure (doors conviction)
then close with the plip; then close with the normal key. the door still does not close .... can anyone help me?
cordially
Tioneb
The door latch will close at times on my Chevy, causing the door not to close and latch correctly. To fix, I have to pull the inside door handle out with one hand and open the closed greasy latch with the other hand. It's like a little flip catch mechanism.
May be the same with the LS
It is possible that the door lock has failed.  If it has failed, it is an expensive part - retail price for the lock assembly is over US$1100 and the cost of labor would likely also be high.
Thanks for your answer. I tried but nothing changed, the door still does not close.
I  don't know if it's the electric door lock out or the mechanical door lock out of order. The price is not the same.
