ES300 Ballast replacement
Hello,
Need some help.
My driver side low beam light stopped working so I ordered some bulbs from ebay they were like $24 for the pair. Replaced the passenger side first since I read somewhere that you should replace both to match light intensity. After replacing both I turned the headlights on and the driver side still did not work. I thought maybe the new bulb is bad so I replaced it with the passenger side bulb that was originally working fine. Nothing, still did not work.
So I am thinking that it might be the ballast from reading other posts on this forum.
So, I'm getting ready to try and replace the ballast on the drivers side.
Can you please direct me to a video or somewhere that walks you through this process?
Thank you in advance.
