Bandit Posted April 23, 2004 Share Posted April 23, 2004 Does anyone know if an 18 X 7.5 Rim with +45 Offset will have any problems with a stock SC400 and an SC400 with Supra Big Brakes? Thanks! Quote Link to comment Share on other sites More sharing options...
AWJ Posted April 23, 2004 Share Posted April 23, 2004 You will probably have a problem with clearing the TT calipers. It depends on the face design of your front wheels and not so much offset as far as clearing the calipers. You will need a combination of good offset to clear the wheel well and then a face design that will clear the calipers. I always recommend test fitting if possible. If you want to run tt calipers the minimum width up front possible (I think) will be 8.5. The offset will be okay for the car at +45. Quote Link to comment Share on other sites More sharing options...
