Diy: Passenger Seat Backflap Fix, Seat Fan Motor, Seat Motor Replaceme
umarali
So the
back of the passenger seat was coming apart due to broken tabs inside. This
back piece comes as one part and cost atleast $150 online and even more from
dealership. Here is what it looks like and i decided to fix it instead of
replacing it.
22124076481_bfbae49bba_k.jpgIMG_3122
by umar ali, on Flickr
1. Move
the seat all the way back and place flathead screwdriver under piece and just
pull up it will pop off easily. Repeat same for other side. You will find one
bolt on each side. I believe 14mm size socket will work.
21491165764_1bdecf62ff_k.jpgIMG_3115
22101452772_fc2cbf1c50_k.jpgIMG_3117
22124076711_156d73fc7e_k.jpgIMG_3119
22124076581_1857692379_k.jpgIMG_3120
21925815690_c0e882dda8_k.jpgIMG_3121
21925815300_db6d8026eb_k.jpgIMG_3125
22114008865_37af093228_k.jpgIMG_3127
21926110178_e9ec081535_k.jpgIMG_3128
21927085619_9210f4b498_k.jpgIMG_3129
22124075781_4f9f66df6c_k.jpgIMG_3131
3. Now
reach under the seat on the floor and pull carpet piece aside. Unplug these 3
plugs from ECU, this is just a precautionary measure not to pop out any airbags
in the seat while working on it. They are easy to remove, just press on tabs
and pull out.
22087813426_d26268e582_k.jpgIMG_3130
22101451742_851d52ea18_k.jpgIMG_3132
5. Lift
the seat from front and remove these 3 plugs from the bottom since the cable
limits the room for movement of seat.
22124075511_643669fff0_k.jpgIMG_3133
22087813016_16acc3f209_k.jpgIMG_3134
This small
clip doesnt comes off easy so i just pulled down on cable since it is just tied
with tape to this clip and easily slide off. Then use nose pliers to take it
out
21492885313_6e739b5192_k.jpgIMG_3135
6. Now
pull the seat all the way back and push it to dashboard.
21491164304_416e306c30_k.jpgIMG_3136
7. Now
from rear seat you can easily work on it. Pull these rubber elastic bands at
the bottom of seat holding flap. This will uncover 2 Phillips screws holding
the back plastic piece.
21926109318_36e7f5d8e0_k.jpgIMG_3138
22087812526_84308f6a8d_k.jpgIMG_3139
22087812426_c910022aa8_k.jpgIMG_3140
Remove the
cable for small LED on the bottom side of the flap. Just push down tab and pull
it out.
22101451002_294c362c76_k.jpgIMG_3141
These are
the 2 screws need to be removed holding the back plastic piece.
21491163624_c09213eedf_k.jpgIMG_3143
Now just
pull the Back down and out. It is held on top by clip only.
21926108858_ce417c2c7c_k.jpgIMG_3145
21492884633_007b6d8693_k.jpgIMG_3144
Since
you got so far, this is the motor which controls the leaning back ofseat, if it
doesnt work this motor needs to be checked.
21926108798_249ce1cd2c_k.jpgIMG_3146
This
motor controls the sliding of seat back and forth
21925813560_715cc53b71_k.jpgIMG_3147
This
motor controls the seat to grow longer at knees.
21492884263_e7a171a544_k.jpgIMG_3148
If
you want to service the seat fan underneath. Just turn filtercounterclockwise
and it comes off. Now remove 3 bolts holding it in place andwiggle off the
ducts but be careful not to rip the ducts. I almost ripped myduct which trying
to take it off.
Unless you live
in very dusty environment for longer period of time the fanstays pretty clean
and need no service.
22087810566_6e9175a26e_k.jpgIMG_3161
22124074131_24b9b45ff5_k.jpgIMG_3150
21492884243_9d12c1ebfb_k.jpgIMG_3151
8.
This is the back part which has 5 broken tabs which hold the flap. Theone with
arrow is the only one left all other broke off.
21491162954_7717c3b116_k.jpgIMG_3153
22087811466_f4ff66a249_k.jpgIMG_3154
9. I
bough cotter pins of size 1/16" x 1/2" and #10 washers fromhome depot
for around $4 total.
22087811346_a449162615_k.jpgIMG_3155
10.This
is the small drill i have which i used to drill holes where the tabsbroke off.
22124073691_fc46ba0edc_k.jpgIMG_3157
11.
Then i put cotter pin from outside and put washer on the inside and bendcotter
pin and hammered down lightly
21927083389_18ccf57d8f_k.jpgIMG_3158
21925812870_e6c6390915_k.jpgIMG_3159
Only
this small part is visible on outer back side but all of them will becovered by
flap except one which is too small to notice.
22124073481_d83bc09e49_k.jpgIMG_3160
Now
just put everything backwards and you have a fixed backseat flap.
Note: it really
sucks that i had to write this DIY twice, i almost finishedfirst time and
closed tab by mistake then wrote it all over again.
It's outstanding to see some diy here...especially fixes that are bulletproof and don't require a colonoscopy at your Lexus dealer. :censored:
It's also great to see your work on MUD.
Steve
  • Like 1
Steve
Ditto !
Paul
  • Like 1
Next tutorial i am planning on is for Spark Plugs followed by hopefully transmission and transfer case fluid exchanged.
As a head's-up if you decide to do a drain / refill on the diff's...according to my parts guy and confirmed by a great indy shop here in Boise (LTS), the drain and fill washers on the rear diff and the fill washer on the front diff are identical. For some reason unknown to me though, Toyota uses a different washer on the front diff drain plug. That's altogether very different than on the 100 series LX as all 4 diff washers are identical.
Transfer case washers are separate animals, as they thread into aluminum instead of cast steel cases.
I should get the washers delivered (Toyota Parts Barn...26% or so off list) this coming Monday. I'll post at that time with pn's and visual difference.
Plugs are simple, but getting to them takes a bit of time. It helps to have a pretty complete selection of 3/8" extensions, u-joint and / or wobble extensions, as well as both u-joint and straight plug sockets.
Keep up the good work, and thanks again for posting both here and on Mud. :)
Steve
  • Like 1
Umarali, part number for diff and trans case sealing washers...
Front diff fill and rear diff fill and drain 12157-10010
Front diff drain 90430-24003
Transfer case fill and drain 90430-A0003
For some reason, there are no magnets on any of the plugs, so Tundra plugs with magnets (flush with the plug for drains, extended for fill) are, I think, reasonably priced upgrades.
You have 4 choices, depending on if you want a plug with a socket for a 10mm Allen wrench or a 24mm (actually, 15/16" works and fits just a little tighter) 1/2" drive socket...You can also get either variety with a long magnet or one that's flush with the end of the plug. The short ones are used for drain plugs and the TC fill plug, and the longer plugs are used for the diff's fill plugs.
10mm drive, long magnet 90341-18035
10mm drive, short magnet 90341-18021
24mm drive, long magnet 90341-18040
24mm drive, short magnet 90341-18057
I'll be draining the diffs and TX later this week when my driveway dries out from the rain.
I'm also taking a very long look at the Motive Power pneumatic filling tool for stuff like this...cheap for the time and mess it will save...wish I'd known about it years ago...
http://www.amazon.com/Motive-Products-1730-Fluid-Transfer/dp/B00I6BG1KI/ref=sr_1_1?s=automotive&ie=UTF8&qid=1445294785&sr=1-1&keywords=motive+products+1730
hth
Steve
  • Like 1
