Vsc Off And Check Engine Light On
You have the fault code "pulled" with a code reader. Once you know the code number, you can search for that number paired with your make and model of vehicle. The code description will tell you where the problem lies.
As long as there are no drivability issues, chances are that it is okay, but I wouldn't wait too long.
Hi there,
Thanks for the response. I called Lexus Canada. The car has recall for Oil Cooler Pipe. It seems to be the offshoot of this Oil Cooler Pipe.
Will know more when I go to dealer on Thursday. Till then I am keeping fingers crossed.
i went to dealer for recall. after fixing the recall. the diagnostics as per them is:
Oxygen sensor 399
+ one ignition coil 324.11
Total 723.11 + 13% tax
But they say still no guarantee the check engine light and vsc off signal will not come back. per them, the tune up is due in another 11k kms, so it better to get tuneup 480.00 + all coils 944.66= 1434.66+ Oxygen sensor 399. In total spend about $2000 today.
the amount seems to be atrocious to me.
I am in toronto, about an hour drive from buffalo. can someone suggest me if it will make sense to go to Buffalo to get it fixed.
Need help please
How many miles are on your odometer? You might want to check with a Toyota dealership.
