VBdenny Posted January 29, 2015 Posted January 29, 2015 One of my neighbor's girls whom I look out for has a 2001 IS300. She recently had new tires installed and when the technicians attempted the alignment, they couldn't because they said there was a hub issue which I admittedly and unfamiliar with the setup. I would appreciate any insight as to what needs to be addressed before I dig into the car. Thanks Denny
lenore Posted January 29, 2015 Posted January 29, 2015 I wonder if the hub retaining nut is loose? This would cause wheel to wobble....
VBdenny Posted January 29, 2015 Author Posted January 29, 2015 They checked and seemed to think internal. I called my tech guy and he will check it out next week.
VBdenny Posted February 3, 2015 Author Posted February 3, 2015 I've got my Toyota Guy coming to scoop up the car tomorrow to check it out. I'll let you know the details when they become available.
lenore Posted February 3, 2015 Posted February 3, 2015 Just from experience, just a month ago, my drive shaft nut came loose. When the car was lifted off the ground the wheel would actually wobble a little. Scared me and I found the detent in the locking nut backed out and was loose. I was lucky I tightened the nut back to 125 ftlbs and made sure the detent was pinged in and so far no problems.
Fred Furrer Posted July 28, 2015 Posted July 28, 2015 Gentlemen. My 2003 IS300 was making quite a bit of "rough bearing noise" in the front end, and at the same time I noticed that the tires were wearing badly on the inside. I found that the driver's side front wheel was noticeably loose and rough sounding when rotated with the tire off the ground. I ordered a new bearing and a new seal from RockAuto.com (Timken bearing, National seal, for a total cost of about $66 including shipping and tax). I used a 12-Ton hydraulic press that I bought from Harbor Freight many years ago which has paid for itself in saved money many times over. Since the IS300 is rear drive, changing the front bearings is comparatively easy (although nowhere as easy as changing front wheel bearings on a 1970's American car). I took pictures of the work and will post them on this forum if I can figure out how to do it. After changing the bearing, I had the car aligned and now it drives smoothly and quietly.
