laxes Posted January 15, 2015 Posted January 15, 2015 FYI to you if you are thinking of buying a Lexus with Airsuspension.. my 2008 LS460L rear suspension thumps while driving down the road- almost constantly. Rear Shocks are leaking (Air suspension - not the Spring Coil option), I checked them visually-yes I can see the grease . the car does raise and lower by 3/4" when the HEIGHT HIGH button is activated which tells me the air bladders are fine; just the shocks are gone. anyone want to guess the price for the part alone on these Air Shocks ? how about a cool grand each side ! w/o sport pkg 4808050153 Right Rear 4809050153 Left Rear w/Sport pkg4808050164 Right Rear 4809050164 Left Rear
1990LS400 Posted January 16, 2015 Posted January 16, 2015 $1,000 per side is a good price since current retail per Sewell Lexus is around $1,550.
laxes Posted January 16, 2015 Author Posted January 16, 2015 ridiculously insanely priced for a part that is only a tad more luxurious than the coil option and has a failure rate as common as a dollar store item.
jainla Posted January 21, 2015 Posted January 21, 2015 I've seen them on parts.com for about $800 and change; never tried to buy one though. I don't know if I would characterize it as 'failure rate as common as a dollar store item'; they seem to generally last about as long as conventional shocks. My mechanic told me my front ones were leaking and I figured I would wait for the air bladders to actually fail; I'm still waiting (it's been 2 years). The ride doesn't seem any worse. The Mercedes and Jaguar units are closer to $2k; and try googling the horrors with the W220 Air suspension (fried compressor, failed springs, trashed suspension etc). You could also try an air spring conversion kit; I didn't see one one Strutmasters but they run about $1500 for all 4 springs for the LS 430; if you call them maybe they can help. Or try this place; although I don't know about the remanufactured springs: http://www.suncoreindustries.com/Lexus-LS460-AWD-2009-2012-suspension.php ridiculously insanely priced for a part that is only a tad more luxurious than the coil option and has a failure rate as common as a dollar store item.
laxes Posted January 27, 2015 Author Posted January 27, 2015 Yes I did look at converting it over to springs but wasn't comfortable with the idea; I like to keep it stock. Thanks
