neezebeeze Posted June 25, 2014 Share Posted June 25, 2014 So i have a problem with my trunk lid. It opens up but it doesnt go up. it just unlocks and i have to manually open it up. im not sure if its the strut since it stays open if i put it up. does anyone have the same problem or an idea of what it might be? thank you. its an 05 ls430 btw. Quote Link to comment Share on other sites More sharing options...
Cliff in Baton Rouge Posted June 26, 2014 Share Posted June 26, 2014 I just purchased my 2004 LS430 with 34,000 miles. Same thing happens to my trunk lid and I thought that was normal behavior. Quote Link to comment Share on other sites More sharing options...
pj8708 Posted June 27, 2014 Share Posted June 27, 2014 Hi Guys and welcome, Looking through our data base the majority indicate the struts are the problem. They have probably lost there charge. But one other point. Recently, I read some notes about not all LS versions have the automatic trunk opening feature. It would depend on the standard OEM features and the feature packages the original owner opt for, Just FYI Below is a link to Lexus customer service. They may be able to help you with feature information. Paul http://www.lexus.com/contact/ Quote Link to comment Share on other sites More sharing options...
landar Posted July 1, 2014 Share Posted July 1, 2014 I believe the trunk lid should just pop open a bit but not go up on its own. You have to 'help' it up to the fully open position. However, it should not take a lot of effort. If it does, then the gas struts are going bad. Another thing to check: with the trunk lid in the fully open position, just nudge it downward a bit. If it slams shut, the struts are shot. If it does not slam shut and, more importantly, does not slam shut on your head all on its own(like mine did), then the struts are ok. Quote Link to comment Share on other sites More sharing options...
eacla Posted March 4, 2015 Share Posted March 4, 2015 Agree with above posts. This is normal behavior. Probably intended to keep the lid from springing all the way up unexpectedly and whacking someone in the face. Quote Link to comment Share on other sites More sharing options...
RudyZ Posted April 8, 2015 Share Posted April 8, 2015 If you get the "extra force" struts from ebay, be aware that closing the trunk lid (from full open) also requires "extra force". BTW the trunk lid does not "spring up all the way up" with the extra force struts. USA made. Quote Link to comment Share on other sites More sharing options...
