2008 Lexus Rx Tail Light Cover Replacement Cost
I'm wondering if anyone has an idea how much it costs to replace a
broken tail light on a 2008 350 RX. Not the lightbulb, but the red
plastic part. I'm told the entire bumper might have to be replaced, but I
wonder if that's actually the case. It was estimated at $650. Thanks
for your help!
The lens on the bumper lamp/reflector is not available separately. The entire unit is $80.07 at http://lexus.sewellparts.com if you register with a Lexus forum member name. You might need a few other minor parts if they can't be salvaged from the damaged lamp unit.
$650 sounds like a bargain if that includes the entire repair.
Alex
I have the same problem. Were you able to resolve your tail light issue and if so how? Does the bumper need to be removed in order to replace the lens?
Thanks.
Dave
