I need to replace the rear wheel bearings in my '05 RX330. Any suggestions or things to watch out for? Thanks, Pete
  • 4 months later...
Hey Lenore I had read your posting on wheel bearing an felt I did a wonderful job until I realize that I had bent the threads on my spindle after taken the wheel bearings off is ther anything you could suggest a afar as replacing the axle cv axle or wat ever they call it I just have been tryn too do it my self with the wheel bearing I need help an not afraid too say I need help I just need proper counsel
Not sure what you mean about bending the threads. If they are torn up or flattened you could take a fine file and carefully file in the direction of the thread path.
