dcfish Posted December 4, 2013 Posted December 4, 2013 I want to replace the sway bar bushings on my 98 G3, Does anyone have a DIY step by step ? Not the end links. TIA :)
dcfish Posted December 7, 2013 Author Posted December 7, 2013 Thanks for the Replies, Much appreciated :)
silverbullitt Posted December 10, 2013 Posted December 10, 2013 what's up dcfish. I have a 98 GS400 & when i changed my sway bar bushings. I just raised & supported the front end, it's like 4 bolts holding the sway bar bracket on each end. once you remove the bracket the bar will tilt. Then you can remove the bushing. when re-installing make sure you use silicone grease to lube the bushings back up. Because if you dont it will make creeking noise. Put the brackets on & tighten up. That's what i did when i replaced mines, step by step. 1
dcfish Posted December 11, 2013 Author Posted December 11, 2013 what's up dcfish. I have a 98 GS400 & when i changed my sway bar bushings. I just raised & supported the front end, it's like 4 bolts holding the sway bar bracket on each end. once you remove the bracket the bar will tilt. Then you can remove the bushing. when re-installing make sure you use silicone grease to lube the bushings back up. Because if you dont it will make creeking noise. Put the brackets on & tighten up. That's what i did when i replaced mines, step by step. silverbullitt, You The Man Thanks a Mint for the info.
