ssdoeg2 Posted September 7, 2013 Share Posted September 7, 2013 Good day all, I'm in the process of replacing the left rear hub bearing and during the removal of the axle carrier I destroyed the bushing for the strut rod ( axle carrier side not frame side). I'm unable to find a part number for it in the shop manual. Vehicle is a 1995 ls400. Any help is appreciated, Many thanks in advance for all your help over the years and letting me have a champagne taste on a beer budget. Recently picked up an ls430 so I'm fixing the 95 to sell. Quote Link to comment Share on other sites More sharing options...
dashan Posted September 7, 2013 Share Posted September 7, 2013 adus 505 Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted September 7, 2013 Share Posted September 7, 2013 I do not see the bushing offered as a separate part and assume it will come with a new strut rod. The part number I see at http://www.toyodiy.com/parts/p_U_1995_LEXUS_LS400_UCF20L-AEPGKA_4804.html?hl=48780A for a rear strut rod is 48780-50020. I see the rear strut rod for at $102.66 at http://lexus.sewellparts.com/oem-catalog/4804480599-PowertrainAndChassis-LS400-1995.html when you register with your forum member name. Quote Link to comment Share on other sites More sharing options...
ssdoeg2 Posted September 11, 2013 Author Share Posted September 11, 2013 Thanks for the replies gents, sorry for the late response but extremely busy. The bushing on the axle carrier side is a part of the axle carrier itself so buying a strut rod woulld not solve the issue. Will go to the stealership I guess to order one, again thanks for your reponses, much appreciated. Quote Link to comment Share on other sites More sharing options...
ssdoeg2 Posted September 11, 2013 Author Share Posted September 11, 2013 Just googled adus 505, did not realize that it was a part number dahsan. Thanks Quote Link to comment Share on other sites More sharing options...
ssdoeg2 Posted September 22, 2013 Author Share Posted September 22, 2013 Good day all, Finally got the bushing and the bearing replaced and reinstalled the axle carrier. When I put the car in gear while up on jacks the reinstalled axle carrier does not spin properly or at all while the other side is ok. I have tightened the axle nut further with no change thinking I did not have the carrier in far enough but I would think the drive shaft should have spun properly anyway. Any thoughts appreciated guys, will try to figure it out and check back online for any tips in a few. Quote Link to comment Share on other sites More sharing options...
ssdoeg2 Posted September 22, 2013 Author Share Posted September 22, 2013 Never mind gents, It's good to go. Guess that's normal what I was seeing. Quote Link to comment Share on other sites More sharing options...
ssdoeg2 Posted September 22, 2013 Author Share Posted September 22, 2013 Forgot to mention that car is nice and quiet now, Will wait on other side to replace bearing as it seems to be ok. Many thanks to all for your support and thanks again 1990ls and Dashan on this issue. Quote Link to comment Share on other sites More sharing options...
