Cracked Plastic Switch Housing On Door Panel
both the left and right door panels (the plastic housing on the power window,lock and mirror switches) on my 95 lexus es300 have cracked. Is this a common problem? Can these be easily taken out and swapped with good ones from a salvage yard? does the door panel have to be taken out?
  • 2 months later...
FWIW, three (3) of these plastic assemblies have cracked on my 94 ES300, all at the same point: the forward ~2" of the assembly. Original and replacement assembly cracked on the driver side door, the original on the passenger door. The replacement assembly was something like $85-$90 about four years ago...which explains why my vehicle has two cracked assemblies that have NOT been replaced (again!)
