04 Rx 330 Tire Pressure Warning Light
popi
The tire pressure warning light just came on, and I've checked all the tire pressures and they are fine. Is there a "reset" button/switch and/or what is the usual problem with type of symptom. Thanks for any feedback you have to offer.
Welcome to the LOC. When you post your questions or comments we need to know bothe the year and full model. For example. 2013 RX350. Every model year may be a little different. Therefore, the information below is for current models.
The spare tire also has a pressure sensor. Its not unusual for the spare tire to cause the low tire pressure light to come on. Fill your tires to the cold pressure amount shown on the drivers side door pillar. The reset procedure is in you owners manual.
Paul
