Gurgling Noise
SHUMIF1
2001 rx300, I have a gurgling noise coming from the right side lower kick panel area under the dash, by the heater and ac box. Coolant and freeon levels are good . I had the kick panel off and the sound is coming from it seems aluminium pipes that are very hot when i touch them. Any ideas what might be causing that noise. I'll try to take a pic or vid to explain more.
could be the the coolant is low in the AC unit. However maybe the heater lines also....without a picture not sure.
  • 3 weeks later...
  • 6 months later...
