Just got a 94 ls400 and I'm looking for a repair manual. Are the downloadable PDF ones worth the effort or should I look for a hard copy?
I dont recall a 94 manual, the ebay Cd's are worthless, you can do a search on here and clublexus.com , and fix nearly anything you might need help with. my first 94 had a busted timing belt on it with 236k miles, but a nice car, even without any maintenance.
good luck, remember to search...
  • Like 1
Hi,
the first generation LS400, I believe is from '90 through '94, so the manuals should have some overlap. The following link posted by some kind soul earlier is for the '92, and in the absence of anything else, will probably be some help, although I cannot say how much.
www.ls400.ru/lexus-89-2000/RepairManual1992.html
Hope it helps.
