Rusty Rx 330 Tail Gate Pistons
rfcbuf
My 2004 RX 330 has rear lift gate pistons which have the outer piston cylinder tips covered with rust and pealing paint. I expect the pistons would probably seize in the next year or two as salted roads are common in Western New York winters. Is this an easy aftermarket replacement procedure and where can the pistons be purchased.
I would expect the job would be considerably more expensive if done by a dealer.
Go on Flea bay and search for hatch shocks and you will find a business that sells them cheap....He includes instructions, but beware the door is heavy so use a ladder with appropriate spacers to hold the door open while changing...
