kyle0k Posted March 9, 2004 Share Posted March 9, 2004 Resently i have noticed the brake pedal has become much harder. I know its not my brakes b\c i jsut replaced them. It brakes really good still if i press it hard enough but insteasd of being sensitive and light how it alwayts was it is now hard almost right away. Does that mean i need to replace or add brake fluid?? if not what else can it be Quote Link to comment Share on other sites More sharing options...
amf1932 Posted March 9, 2004 Share Posted March 9, 2004 It sounds like you have a problem with the Power Brake Booster. On the booster there is a hose that goes into this booster. Make sure it's connected properly and you don't have a vacuum leak. You can check that you have vacuum by taking off this hose from the booster and check whether there is vacuum coming from the hose. If you have vacuum then it could be an internal problem with the booster itself. If you don't have vacuum coming from this tube then check out the complete tube from the intake manifold to the booster. BTW: The engine has to be running to do these checks. Quote Link to comment Share on other sites More sharing options...
kyle0k Posted March 10, 2004 Author Share Posted March 10, 2004 wheres the booster at Quote Link to comment Share on other sites More sharing options...
amf1932 Posted March 10, 2004 Share Posted March 10, 2004 The booster is behind the brake master cylinder(where you put in brake fluid) on the driver's side firewall. It's the round thingy where the vacuum hose is attached to. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted March 14, 2004 Share Posted March 14, 2004 How old is the brake fluid in the car? when was the last time you had brake service? Quote Link to comment Share on other sites More sharing options...
