Sc400
I found the DIY for the In Cabin Air Filters.
http://web.ace.net.au/soarer/air_conditioner_filter.html
I then went to remove them from my 93 SC400 and everything was going well until I removed the door for the Air Filter. No Air Filter! I do not know if they have been removed or were never present, but there is a place to install them.
My next question is, where can I find the information to order a replacement filter?
Was this a Japan only option, because of smog and everyone smokes?
Any help would be greatly appreciated.
I'll check the Lexus dealer and see if they can order this.
:cheers:
Completed a little research and found the following:
The Incabin Air Filter is available from a Lexus Dealer for $63.00
PN: 88880 24020
All SC's have the compartment for this filter, but not many had it installed.
This may have been a dealer option and most saved the money and did not install.
When I opened my compartment up, there was alot of fine dust and lint on the cover. It seems that this would be a good option to install.
The filter looks much like a K&N and could be cleaned with soap and water and reused. It would also be a good way to add a little air freshener to the filter before installing.
I hope this helps anyone thats interested.
:cheers:
