What Size Of Nut On The 93 Es300 Rear Bearing Hub Assembly?
davidh
I only have one car. I need change the rear bearing since it was broke.
I need to find out what size of nut on the 93 es300 rear bearing hub assembly before replace the rear wheel bearing. I am afraid I do not have right tool to take it out after I disassembly it.
Did anyone know what size of nut on the 93 es300 rear bearing hub assembly?
Thanks for help
David
can't find the spec in the haynes. my guess from the diagrams it's 17 mm, get the machine shop that's going to press in the new bearing to take it off and torque it back on. don't try to do that yourself. you may be able to get a bearing hub assembly for not too much, as it is w/ another toyota I have
LL
