Timing Belt
HappyLS430owner
Several weeks ago, a serpentine belt was installed. An effective cure for squeeking.
My car has 160,000 miles on it and going strong. No real issues. Today, there was a pinging noise and then the car conked out. OMG. The tow truck brought it to my home for Turkey Day holiday and the operator thought it might be a timing belt problem, tensioners, stuff like that. Does this sound familiar?
Sorry to tell you but if the timing belt has failed the engine will have suffered major and expensive damage from valves hitting pistons so I hope it hasn't.
A mechanic will know as soon as the top cambelt cover is removed.
Please come back with the cause when you know.
Nearly forgot welcome to the LOC and a Happy Thanksgiving Day.
That's not good then, BTW if the cambelt snaps the damage is done before the Engine Management Light even flickers it's all over in a fraction of a second.
Best way is to source a known good and warranted low mileage engine straight from Japan and replace the cam belt before you fit it.
