David N Posted October 21, 2012 Share Posted October 21, 2012 Please point me to the right direction on How To fix this issue (VVTi Oil control valve filter location OCV) - Any one has the picture of its location and how to change it would be very much appreciated. -Dav Quote Link to comment Share on other sites More sharing options...
lenore Posted October 21, 2012 Share Posted October 21, 2012 here you go... http://us.lexusownersclub.com/forums/index.php?showtopic=68108&pid=427462&st=0entry427462 Quote Link to comment Share on other sites More sharing options...
David N Posted October 31, 2012 Author Share Posted October 31, 2012 Thanks so much Thomas - P1349 VVT System Malfunction (Bank 1b) blocked oil control valve filter - Do you also have the picture location of this "Oil Control Valve Filter". Thanks. Dav Quote Link to comment Share on other sites More sharing options...
lenore Posted November 4, 2012 Share Posted November 4, 2012 no picture of that but go to sewell lexus site and the part may be shown Quote Link to comment Share on other sites More sharing options...
chococat Posted December 9, 2012 Share Posted December 9, 2012 Actually it could be 1) filter 2) oil control valves 3) wiring 4) ECM. My mechanic said ECM. I disagreed. Took my car home. I started with filter. (10 min job) They were clean. Replaced the OCVs. (I believe in doing things in pairs) (10 min job). Code went away. HOWEVER, bank 2 is tricky & my wire casing are brittle in areas, so my housing connecter pulled away from the wires a little, so while my P1354 (bank 1) went away, I sprung a new P1359 (bank 2). The P1354 for the OCV. The P1359 for ME was wiring. The P1354 caused my timing to advance wrong on one bank & the car lurched, smoked, etc. The P1359 causes no problems whatsoever except an engine light. I hope this helps. ^_^ Quote Link to comment Share on other sites More sharing options...
