lexusquebec Posted August 15, 2012 Share Posted August 15, 2012 hello i got a is 350 2007 when i activate the cruise control button the light in the dash stay green but i cant set a speed. i need help to resolve this problem thx Quote Link to comment Share on other sites More sharing options...
CrunchySkippy Posted August 15, 2012 Share Posted August 15, 2012 I'm assuming that when you say "activate" you are performing both the "on" and the "set" tasks, right? If so I would check for a burnt fuse. Good luck. Quote Link to comment Share on other sites More sharing options...
tex2670 Posted August 15, 2012 Share Posted August 15, 2012 I'm assuming that when you say "activate" you are performing both the "on" and the "set" tasks, right? If so I would check for a burnt fuse. Good luck. Yah--turning the cruise "on" doesn't set your speed. First you turn it "on", get to the speed you want, then hit "set". If you have to deactivate, you don't hit "off"--you either push "cancel" or hit the brake. Then if you hit "resume" it will go back to the previously set speed. Quote Link to comment Share on other sites More sharing options...
lexusquebec Posted August 15, 2012 Author Share Posted August 15, 2012 ya i understand how the cruise control "work" cause it the same on my toyota celica 2000 guys but i cant set a speed when i push it down Quote Link to comment Share on other sites More sharing options...
lenore Posted August 15, 2012 Share Posted August 15, 2012 Maybe the brake switch is bad....Sometimes they have a two part switch for brakes which disingadges the speed set. Quote Link to comment Share on other sites More sharing options...
