Combelis Posted May 17, 2012 Share Posted May 17, 2012 Hello, I have a 1995 ES300- just repaired the transmission. when opening the switch on (even before starting) the O/D lamp blinks on. I checked with Texa scanner the DTC and i got P0753 (solenoid A) ohms on the solenoids were inspected =14.9. the vehicle runs fine, nothing wrong at the AT. vehicle speed sensor runs fine. ECT sensor gives correct values. Is there any thing else to check? thx, Etai. Quote Link to comment Share on other sites More sharing options...
paulenka1 Posted June 5, 2012 Share Posted June 5, 2012 i think you can get a code scan tool to clear the fault code, which one get, depend on your car's modle and year. ___________________________ never give up! http://www.chinasinoy.com Quote Link to comment Share on other sites More sharing options...
lenore Posted June 5, 2012 Share Posted June 5, 2012 Is the car really going into overdrive, check your RPM's I suspect your transmission is going.... Quote Link to comment Share on other sites More sharing options...
bruceyou Posted September 11, 2012 Share Posted September 11, 2012 yes,you need some diagnostic tools to check. Quote Link to comment Share on other sites More sharing options...
