I looked under the FAQ's to see if this question has been asked already , so here it is. What years and other Lexus models parts (Interior & Exteririor) are compatible with my 95 SC 300 ?
It depend on which part...
But 1992-2000 sc300/400 share quite some identical/similar parts.
Exception made of engine, exhaust, suspension, etc. on which you should especially take time to check carefully. They often differ between sc300 and sc400 but also thru the years...
Be sure to verify the compatibility each time for others parts but most will fit directly or with minor modifications.
Have a nice day
  • 12 years later...
 Hi I hope you guys can help me out I have a95 Lexus sc400 and my windows won’t go down I’m thinking it can be the power motors but I research it runs from $400ish and I have no idea about cars I’m a girl by the way but I heard someone told me most Toyota parts are compatible can anyone help me out
Welcome, Tammy!
You may be able to ask a Toyota parts department person to cross-check. I'd guess that most independent mechanics can troubleshoot the issue. You shouldn't buy parts before they do. Alternately, a Toyota dealership should be able to do the same, likely at higher cost, but lower than a fix by a Lexus dealership.
