SHUMIF1 Posted February 24, 2012 Posted February 24, 2012 I can't seem to remember from my 99 rx , but does the front overhead light supose to come on when you open the drivers door ? It works when i push it to light up. My center one comes on when i open the drivers door.
kingnba6 Posted February 24, 2012 Posted February 24, 2012 i dont think the front is supposed to go on.
Filehorse Posted February 24, 2012 Posted February 24, 2012 Only the overhead light comes on when the door opens. You'd think the front overhead light would also come on but you'd be wrong.
jaswood Posted February 24, 2012 Posted February 24, 2012 I can't seem to remember from my 99 rx , but does the front overhead light supose to come on when you open the drivers door ? It works when i push it to light up. My center one comes on when i open the drivers door. Only the dome light just behind the front seat comes on. I replaced mine with a Ford Map/Dome/Curtesy light. Wired it so all three bulbs illuminate with an open door. Helpful aspect is that left and right map light bulb fully illuminate the front seats and the floorboard/dash area forward of the front seats. Also, the front passenger can use, individually, the new map light without interferring so much with the driver's night vision. If you wish you can easily wire the front light in parallel with the rear dome and have both come on with a door opening. You can also wire the front light switch such that it only turns on the passnger's new rear, over-the-shoulder, map light.
SHUMIF1 Posted February 24, 2012 Author Posted February 24, 2012 thanks so much. i will rewire that front light..lol
