Hey guys I am new to the forum, just curious. About a month ago I purchased my 01 gs430 and it makes a funny squeeking noise from what sounds to me as the front struts. I can only hear it at very low speeds and when i go over bumps. Car has 104k miles on it all maintenence is done runs perfect just want some insight on what the problem may be.
Thank you.
  • 4 weeks later...
Change your upper & lower control arm bushings, you have 2 lower control arms. strut mounts, sway bar links. If u can't find a shop to press out the bushings, have them replace. Also you mite as well replace your struts in the process. Just found out struts only last for 50k miles.
