Ed F Posted December 28, 2011 Share Posted December 28, 2011 Hi, I have a 1998 SC300, 104,000 miles, automatic. At 4000 RPM a vibration and or vibrating noise starts then increases in intensity to around 4800 rpm. It then completely goes away. I first noticed it when I dropped into passing gear on the highway, but I can duplicate the vibration/noise by just running the car in 1st or second gear up to the rpm range. The dealer just put a timing belt service in and replaced the VVTI that was also leaking. They can't seem to figure this out after several days. Mounts have been checks and cat convertors are new. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
pj8708 Posted December 30, 2011 Share Posted December 30, 2011 Hi, I have a 1998 SC300, 104,000 miles, automatic. At 4000 RPM a vibration and or vibrating noise starts then increases in intensity to around 4800 rpm. It then completely goes away. I first noticed it when I dropped into passing gear on the highway, but I can duplicate the vibration/noise by just running the car in 1st or second gear up to the rpm range. The dealer just put a timing belt service in and replaced the VVTI that was also leaking. They can't seem to figure this out after several days. Mounts have been checks and cat convertors are new. Thanks for any help. Hi Edward, Apparently you have everyone stumped. I don't have any help, but hang in there any hopefully after the holidays somebody will chime in with some ideas. Quote Link to comment Share on other sites More sharing options...
Ed F Posted December 30, 2011 Author Share Posted December 30, 2011 Thanks, I have an idea I'm working on tomorrow. I noticed the noise and a vibration in the fan and I am replacing the clutch. It makes the same noise in park at the same RPM's and you can see the clutch vibrate at the same RPM. It wobbles a little when I wiggle it with my hand but it definitely looks and sounds like it is coming from the fan. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 30, 2011 Share Posted December 30, 2011 It sounds like the Fan-Bracket isn't tightened down. let us know how it goes. Quote Link to comment Share on other sites More sharing options...
Ed F Posted December 30, 2011 Author Share Posted December 30, 2011 It sounds like the Fan-Bracket isn't tightened down. let us know how it goes. Replaced the clutch and the vibration and noise is 90% + gone. Anything left over may be my imagination and I am revving it up to 4-5k anyway but this seemed to fix it. Used a US made replacement, no problems in doing the switch, took about 20 minutes. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 30, 2011 Share Posted December 30, 2011 Excellent. The 2JZZ engine is pretty smooth so there shouldn't be any vibrations. Pull the throttle cable a bit and see if anything else sounds out of place. I hope this fixes the issue. Let us know if there's something else. Quote Link to comment Share on other sites More sharing options...
