Rx 300 Sun Visor
COMike
This may seem like a silly question but our RX driver's side sun visor does not stay up. You push it up into the recess of the ceiling
headliner and it falls down to about a 45 degree angle. Constantly gets in the way of your vision and you almost always hit your head on
it when getting into the vehicle. I have looks and looked at a way to tighten this up all to no avail. Does anyone know of a way to
make this tighter or will I just have to buy a new one?
Anyones help and advice is appreciated
Hi Michael, Sun-visor issue is a common concern amongst Lexus owners. I too have the same problem. Only remedy is to replace with a "new" (strongly against it. Too expensive), or a used one that still stays up.
Roland
  • 1 month later...
Had the same problem on my rx300, short of replacing you can use a plyer to crimp a section of the visor where the rod goes into it about 2 or 3 inches from the point of insertion. You may have to do this a couple of times.
  • 2 years later...
