Clunk!
waf102
1990 LS400 214k+ miles
I have noticed that during the past few months I have had a hard 'clunk' when putting the car into reverse after starting up (high idle).
If the car is warmed up (low idle) and I put it in reverse then it's smooth.
I do not have any detectable problems going into any other gears at high or low idle.
I drain and fill transmission oil (no flush!), only use T-IV, and have had the issue before and after the latest drain/fill. The level is correct.
So...Transmission issue? Worn support? Drive shaft/bearings?
(Yes, I looked at other postings, but didn't find same issue with same conditions.)
Thanks!
-Bill
P.S. Also...may not be connected...but...I also notice that occasionally the rear of the car feels like its going over a slightly rough road (best I can describe). It's very slight...and I do need new struts in the rear. Maybe I'm being over sensitive....
Sounds like it could be lose bearings or your drive train. Either way, not a problem worth letting get worse. Lexus or not, cars should not be making a "clunking" noise. I would take it into a Lexus dealer or shop before it gets more severe (aka more expensive).
Bearings or drive train??? Could you put a finer point on it?
Could be U-Joints in the drive axle. They wear over time and can get sloppy. I would also check engine and transmission mounts. The rubber breaks down on those and the engine might not be held in place as firmly as it once was.
